View unanswered posts | View active topics It is currently November 20th, 2025, 4:49 pm
 Carb return spring outer replacement
gym bunny
Post Carb return spring outer replacement
Any ideas? I've hauled the spindle out the carb but it is still a mystery. :?
I need to change the broken outer carb return spring as its broken but I haven't a scooby how?! Currently my throttle sticks and it makes D*lly a real pig to drive and my brakes hot!
Any clues?
Tim
1299cc FTW
September 3rd, 2012, 9:19 pm
Post Re: Carb return spring outer replacement
These may be help...
Looks like you're close.
I've Been Wrong Before.
September 4th, 2012, 10:53 am
gym bunny
Still no wiser... Thanks for the pics though.
Perhaps I need to grind the end off and then weld it back on?
1299cc FTW
September 4th, 2012, 12:10 pm
mines broken too tim,! ill take pics in a min and post them
its a spare carb that i,m refurbing , bear with me---
the new spring is the first thing to fit ,then thefunny shaped metal plate then the second spring, then pass the shaft through the carb body
September 4th, 2012, 2:00 pm
all i was going to do was fit a long return spring to the throttle arm to pull the arm back and just leave the broken spring in place :lol:
September 4th, 2012, 2:26 pm
gym bunny
http://m.facebook.com/home.php?refid=0# ... =594675293
Sorry, at work so using my phone. How do you get that bit off? Am I being too gentle?
1299cc FTW
September 4th, 2012, 2:41 pm
a,hhh, i see what your saying tim-- i think ken may know the answer to that
sorry i don,t know
September 4th, 2012, 3:13 pm
gym bunny
I want to replace the smaller outer spring between the bendy outer plate and smaller inner plate that interacts with the other bits.
I'll do some more pics later to try and explain.
Thanks
Tim
1299cc FTW
September 4th, 2012, 3:19 pm
About to do this job too, I'm a bit behind. that end bit SHOULD come off the spindle so you can get at the springs. Is it going to be at brute force job to pull it off? Bollocks I was hoping that was going to be the easy fun bit :evil:
Ben
September 4th, 2012, 6:49 pm
Further to previous post now at same stage as you. I've managed to twist my spindle :oops: :cry: So err on the gentle side for now! will now have to get the spare one off the spare carb, but the screw heads on that butterfly are worn out, can't get a turn on them :evil:
Ben
September 4th, 2012, 9:03 pm
