View unanswered posts | View active topics It is currently November 20th, 2025, 3:19 pm
 Battery drain when running.
Post Battery drain when running.
Does anybody on here know what the ampere hour drain is when a 12 volt 2CV engine is running? No other drains involved, just the engine and no input from an alternator. I'm trying to work out running times on a battery alone, no charging system and no lights.
Brooky.
www.stockwell-lodge.co.uk
August 19th, 2012, 12:15 am
Post Re: Battery drain when running.
just the ignition& coil, and of course the strarting motor unless you used the starting handle :lol:
if the batterys new is a consideration
if its old well its conjecture
the battery will have the output& date of manifactuer printed on it,but if its not being charged its an uknown quantity :roll:
i might be wrong
August 19th, 2012, 12:26 am
Brooky,
it would depend on the primary resistance of the coil, if it's a standard 2CV coil with 3.5 ohms and say 50% dwell on the ignition, that would pull an average of just under 2 amps.
Stay away from the brake pedal (3.5 amps) :roll: and divide the rated amp-hours of your battery by 2, then 2 again to give you a reasonable factor of safety in the 'get you home' stakes. ;)
Or carry another battery, but don't forget that running a standard battery right down will reduce its service life.
Maybe a leisure battery would be more suitable, as they're claimed to cope with deep discharge usage.
Brooky.
August 19th, 2012, 12:58 am
Thanks Ken, that's excellent. I was thinking that a leisure battery might be a better option. The question was in fact, not actually concerning a 2CV but my 1934 Morgan three wheeler, which is running a 2CV coil. So your figures still apply. I'm intending to run it in 'stripped down racer style' with no lights (bar a brake light, oops!) and no mudguards. The car also has no starter motor so no enormous coil-robbing drain there either. Not really worried about the MOT situation as I soon won't need one. Happy days!
Brooky.
August 19th, 2012, 8:54 am
Brooky,
that sounds like great fun, I think a photograph or two may be requested. ;)
With the benefit of a good night's sleep, a couple of ideas;
Fitting an led brake light would reduce its consumption to next to nothing.
Using a 'points assisted' ignition unit such as the Boyer Bransden ID or a Velleman kit would allow the use of slightly wider points gap/lower dwell, with reduced current draw for your ignition.
August 19th, 2012, 11:43 am
Thanks Ken. Yes, I was aware of automotive LED bulbs but failed to make the connection in my brain that I could, in fact, use one! As to the CDI ignition systems, I must look into that as they seem stupidly cheap for quite a lot of benefit, apparently. I'll have to find a good hiding place for it though!
Brooky.
August 19th, 2012, 7:44 pm
With such a low drain, I wouldn't worry too much about hurting your battery. What are the chances of you actually running it completely flat each time anyway?!
Surely you'd get the best part of 20+ hours running given Ken's figures - ain't that enough (or are you going for endurance racing... :P )
August 20th, 2012, 12:07 pm
http://www.mmbalmainauto.com.au/PDF/Sta ... teries.pdf :roll:
The problem is that unless the battery voltage/state of charge is monitored accurately, it's very easy to run it virtually flat, with the consequence being much reduced service life.
August 20th, 2012, 12:16 pm
Crikey Ken, I never realised there was so little 'indicated voltage' difference between a fully charged battery and a flat one. I guess I shall need to add a voltmeter to the dashboard. That's ok, I can put it where the light switch won't be! I'm not planning on 20+ hour journeys but I will be carrying a spare, fully charged battery and both will be leisure batteries. Not a problem as I work on a caravan holiday park with a well-stocked accessory shop!
Brooky.
August 20th, 2012, 11:31 pm
Brooky
Marine battery's tend to have a bit more grunt. Maybe worth a thought ?
August 21st, 2012, 9:05 am
