View unanswered posts | View active topics It is currently November 20th, 2025, 6:58 pm
Reply to topic  [ 10 posts ]
 Stupid electrical questions
Post Stupid electrical questions
Having been told by several people last weekend I should actually look after my car abit more, decided ima fix everything that's broken on it before snet.
Firstly, on the two relay changeovers for dim dip, what does the middle "87a" socket connector do? Anything important? I've got a spare relay but it was designed for some spot lights. I've put it on and it works fine, but there's no middle socket for it.
Secondly, my oil warning light's becoming more and more intermitant. No loose connections or anything. I think its the sensor. Guessing this is buried somewhere behind all the horrible crumbling rubber shit on the engine. Is it worth bothering about it or not, as I've been told if it comes on its either a dodgy sensor or your engine will be already be well knackered by the time it comes on.
Thirdly, cheers for reading this utter bollocks.
JK
August 17th, 2012, 6:26 pm
Post Re: Stupid electrical questions
is this any good to you james?
August 17th, 2012, 6:34 pm
i cant work out how to post on here
August 17th, 2012, 6:36 pm
2 2cv Wiring dim-dip.pdf
August 17th, 2012, 6:39 pm
cheers for that.
james - No its a switch over relay thats in the sysytem where a trigger ( ignition on ) switches one circut( parking lights) over to the other (dipped beam via resistor)
just bin the dim dip - see Louis thread about switches actually being on fire innit*.
*down wv da kids me
August 17th, 2012, 7:02 pm
Cheers G-unit. Should have a look before postin jibber ish. Only thing is I thought my dim dip had already been binned off as the tin thing On front of chassis isn't there.
August 17th, 2012, 7:27 pm
i quite like my dip /dim :D ive used it quite a bit,!- but thought it was a fault on the wiring at first :roll: switch is cool
mind you , i,m a bit dim :lol:
August 17th, 2012, 10:35 pm
If the only part of the system that has been removed is the resistor (cylinder on the front chassis cross member) then the dim-dip feature will no longer be working, however the relays will still be doing their best to overload the side light contacts in the switch.
i.e. You've got the worst of both worlds, bin the relays and fit a jumper lead as per the pic in Louis' thread.
August 18th, 2012, 12:00 am
Cool price when the @ffin' dim-dip has cooked your switch... :roll:
http://www.ecas2cvparts.co.uk/lighting- ... p-244.html
August 18th, 2012, 12:40 am
