View unanswered posts | View active topics It is currently November 20th, 2025, 4:49 pm
 Swinging arms
Post Swinging arms
A strange question but has anyone cut up a swinging arm,I was just wondering how thick they are,as I will have to use a hacksaw as there is no power where I'm thinking of doing this and I don't have the luxury of a battery power angle grinder :lol:
July 30th, 2012, 2:24 pm
Post Re: Swinging arms
Here's a couple of Ken's photos. Looks to be about 2mm.
[url][url=http://www.flickr.com/photos/30132857@N06/6501498761/]Image[/url]
IMG_3822 by slcchassis, on Flickr[/url]
[url][url=http://www.flickr.com/photos/30132857@N06/6501497799/]Image[/url]
IMG_3820 by slcchassis, on Flickr[/url]
John Jordan
July 30th, 2012, 2:57 pm
whyyyy?
3mm?
July 30th, 2012, 6:10 pm
Sean wrote:
whyyyy?
3mm?
One of my swivel housings has a very duff thread for the bottom plug ( not my doing ) I have located a 2cv/Ami chassis that the swivel housings look fine on. I intend to unbolt the arms if possible,but as the chassis is at the top of a bank and has the odd small sapling growing through it,so it might not be possible,hence the idea of hacksawing them through,whcih I would rather not have to do,but needs must also the mounting webs forthe knife edges are all bent :?
Thanks for your reply and the pic :P
July 30th, 2012, 6:38 pm
ami may have the larger bearings
July 30th, 2012, 7:25 pm
Ami arms are thicker.
Ami rear arms are smaller 1220mm insted of 1260mm (Track width??)
Ami super front arms are wider!! (Track width??)
July 30th, 2012, 11:42 pm
To be honest, it sounds like a lot of fart-arseing about when 2cv arms aren't hard to find. I've probably got a couple you could have, although they're in the UK. Might be easier to whip the arms off then take them back to somewhere with tools/equipment, all you'd need then is a 14mm socket, snips and a decent sized flat screwdriver and hammer. And maybe take tools to separate the steering arms if they're still attached.
July 31st, 2012, 12:50 am
Russell I only want the swivel housing,however having Taken arms off I know it's not that hard,but the chassis is upside down and held so by a sapling or two,At least I will have to cut the steering arm. Thanks anyway :mrgreen:
July 31st, 2012, 10:15 am
So 2cv chassis DO grow on trees in France. :lol:
John Jordan
July 31st, 2012, 1:54 pm
Upside down, you say?
Take your trusty 6 point 17mm socket, a breaker bar (and a hammer to give those axle bolts their 'wake up' call ).
You may still have to do some woodcutting as well as knocking out the knife edge pins, but at day's end you should have a pair of front arms, maybe some good steering arms and there'd also be an Ami front cross member/axle spare to bung on Leboncoin... ;)
July 31st, 2012, 2:13 pm
