Steering rack guide bush
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4089
Page 1 of 1
Author:  dave 411 [ July 18th, 2012, 8:40 pm ]
Post subject:  Steering rack guide bush
Has anyone fitted one?
Bought one off Roy,it nedds to be "staked" onto the rack.Just cant see how to do this and make the bush a permanant thing.
I have tried what Roy said to do but this just doesnt seem to work.
I think a quick zap with a mig would do the job,but just want to see if anyone has any other ideas.
Ta.
Author:  2CViking [ July 18th, 2012, 8:51 pm ]
Post subject:  Re: Steering rack guide bush
Done several but not without plenty of trouble. The reproduction rings vary a lot in interal diameter. You will find 2 types most common is the ring secured with a rivet, others not so common are the staked.
In most cases I fit them using a counter sunk screw secured with a nut + 2 ugly welding spots on the back. Job done
Author:  dave 411 [ July 18th, 2012, 9:51 pm ]
Hi Pete,thanks for the reply.
The ring I took off was riveted on,but the new one has no hole for a rivet and has to be "staked" on.
I think a blob of weld should do the job at the back of the ring(opposite the holes for the pins).
Rick P said that was the thing to do :) so I think I will go with that.
Cant see how staking or any other way apart from a blob of weld will do.
Unless someone has another idea.
Author:  ken [ July 18th, 2012, 10:39 pm ]
Dave,
if a replacement guide/sliding bush is loose on the rack, I pack it out with an old feeler gauge then use 3 dots of weld on each side to hold it in place.
Selective assembly applies when choosing the thickness of feeler gauge to use, of course... :lol:
Author:  ayjay [ July 19th, 2012, 11:50 pm ]
as usual brilliant advice ken :D
Author:  dave 411 [ July 20th, 2012, 7:46 am ]
Thanks Ken and Rick.
The bush will be blobed today,back on the van tonight :D
