View unanswered posts | View active topics It is currently November 20th, 2025, 4:49 pm
 Suspension set up on the Van
Post Suspension set up on the Van
Any tips on setting the suspension on my van?
Would the settings be the same as a car ?
Any info greatly apprieciated.
July 13th, 2012, 9:30 am
Post Re: Suspension set up on the Van
I guess there must be a proper way of doing it, but I set Hetty up so she 'looks right.' My pet hate with vans is when the rear wheels aren't centred in the rear arches :evil: So I made sure the wheels are nicely centred and dropped the front a bit to give a 'nose down' stance.
July 13th, 2012, 9:43 am
Cut and turn the front arms about 5mm, add around 3 degrees of negative camber. Wind the tie rods out until the chassis is about 35mm from the ground at the front shocker mount and 45mm at the rear. Cut the back axle in the middle, bend it down until you have around 2 degrees more negative camber on them, stand back and admire your awesome looking van
July 13th, 2012, 6:00 pm
Now Now Russ,its going to be as original as I can make it :P ,but I was going to ask about whats involved with lowering the D*lly.How low will it go on the standard set up,and will the handling change?
I see you all talking about turning the front arms,whats that all about?
July 13th, 2012, 6:16 pm
35mm or 45 mm ?? you mean 35 or 45 Centimeters !!
July 13th, 2012, 8:15 pm
No, i mean mm!
July 13th, 2012, 8:19 pm
Thats low :lol:
July 13th, 2012, 10:06 pm
Regarding your van, as Sam says, do it so it looks right to you. Use reference pictures if it helps.
July 13th, 2012, 10:10 pm
When I said set up,I didnt mean height,I meant the threaded tubes that go into the cans.
July 13th, 2012, 10:29 pm
Yeah, same as a car.
July 13th, 2012, 10:57 pm
