***kin STEERING LOCK !!!!!!!
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
Came back from supermarket,parked stupidily to unload.......Shopping out I went ti move the car.....Key would not go back in then I broke it in the struggle.....F*ck !! So car immobile in a stupid place, what to do next...Thank goodness for battery powered tools...An hour later, skint knuckles, LOTS of swearing, burnt finger and the column is loose. A couple of bolts with most of the head removed allowed a temp securing of the column and a surprisingly simple hotwire and we are back in action! Sooooooo, whats the alternative to 100 quids worth of replacement lock? New clamp is a given, what size is the nut? I'd rather not use shear nuts... Last thing I needed tonight Cheers Gerry
| June 30th, 2012, 10:25 pm |
J-dub
 Re: ***kin STEERING LOCK !!!!!!!
Gerry I had this once, i gave it a touch of Wd in the lock and bob was my uncle once again i geuss its too late to say that You can disable the steering lock in 30 seconds on a 2cv, its un believable easy, as for hotwiring, i always carry my hot wire kit in the boot just incase  even got proper 2cv connections from a 2cv loom to make it plug and play quickly
| June 30th, 2012, 11:45 pm |
48pop wrote: Sooooooo, whats the alternative to 100 quids worth of replacement lock?
Cheers Gerry
a second hand one? ( and next time remove the collar from the column so it never happens again) Ubolt is 11mm M7
| July 1st, 2012, 10:07 am |
48pop
When I got it off, the collar flew over the nearest hedge......
| July 1st, 2012, 6:02 pm |
48pop
Devils Advocate
Once is careless, but twice...
| July 2nd, 2012, 10:26 am |
Devils Advocate
48pop, what new parts do you need? Replacement barrels - for the ignition and 2 doors - is around £25 akaIk. And you'll have 3 new keys too...
| July 2nd, 2012, 10:38 am |
not on a 2cv its not - ignition lock with cast housing and big key £99.50 plus postage, totally un related door keys and barrels 2 of, 2 keys £14.30. Seans big shed of bits = beest priiiice
| July 2nd, 2012, 5:58 pm |
Nelsthebass
Just leave it disabled and use a flick switch and push button start panel that you can get off of fleabay for a few quid and buy yourself a Krooklock!
| July 2nd, 2012, 6:16 pm |
ayjay
mine has that-- the original key lock jammed up ages ago mine has a metal plate with a s/hand ig switch and a press button now
| July 2nd, 2012, 6:23 pm |
Users browsing this forum: No registered users and 5 guests |
