| Odometer going insane. http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4036 |
Page 1 of 1 |
| Author: | Little Louis [ June 19th, 2012, 7:08 am ] |
| Post subject: | Odometer going insane. |
Right so two weeks ago my speedo was on about 53408, now its 64600, why is the speedo telling me I have done 9000 miles more than I have? although it's giving me an unbelievable mpg I'd rather it be accurate! |
| Author: | J-dub [ June 19th, 2012, 8:41 am ] |
| Post subject: | Re: Odometer going insane. |
Sounds like the magnet inside isn't doing its job correctly? |
| Author: | knightley [ June 19th, 2012, 10:05 am ] |
The magnet just indicates the speed. The odometer is driven by gears and ratchet and pawl. |
| Author: | Joolz [ June 19th, 2012, 11:13 am ] |
The speed that the odometer turns relative to the wheels is controlled by gears, a cable, and more gears. It's quite possible to see how it could under read if something was slipping, but over reading is very odd. Perhaps if a cog's worn it could be rubbing on the one next door, and bypassing one of the reductions? Whatever, you'll need to take it out for a look, and then replace it if you can't see anything. Either that, or you need to stop leaving the keys in it. |
| Author: | J-dub [ June 19th, 2012, 11:49 am ] |
Ah of course I forgot about the gears |
| Author: | Little Louis [ June 20th, 2012, 7:30 pm ] |
what dictates when it turns is there a latch I could have knocked out of position when re paining it ? |
| Author: | J-dub [ June 20th, 2012, 9:34 pm ] |
There are small clips on the digits. Take it apart it's quite interesting.. Don't take the needle or face off though |
