International2cvFriends.com http://international2cvfriends.com/forum/ |
1299cc Pinking http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4033 |
Page 1 of 1 |
Author: | Tim2cv [ June 18th, 2012, 8:06 pm ] |
Post subject: | 1299cc Pinking |
Under load or low revs 5th gear pinking is very noticeable. Any ideas whats causing it or where to start looking? Should i avoid cheap ASDA fuel (129.9 / litre) Cheers Tim |
Author: | ken [ June 18th, 2012, 8:16 pm ] |
Post subject: | Re: 1299cc Pinking |
Tim, assuming the timing is set correctly in the first instance, might be worth checking whether the vacuum advance/retard is working OK. There should be a small bore vacuum pipe connected between the carburettor and the distributor. ken Tim2cv wrote: Under load or low revs 5th gear pinking is very noticeable. Any ideas whats causing it or where to start looking? Should i avoid cheap ASDA fuel (129.9 / litre) Cheers Tim |
Author: | Russell [ June 18th, 2012, 8:37 pm ] |
£1.29 a litre? You can't buy water down here for that! |
Author: | lpgo [ June 18th, 2012, 9:58 pm ] |
I think you have conterweights, try to back up them a little (bend them) so you have less advance. I hope you know what I mean.... otherwise I try to explain it better........ |
Author: | J-dub [ June 19th, 2012, 12:16 am ] |
Russell wrote: £1.29 a litre? You can't buy water down here for that! Russ the fuel station near me = 129.9 petrol 133.9 diesel |
Author: | Tim2cv [ June 19th, 2012, 7:56 am ] |
Need to unpack my timing gun then and have a check. As for the little vacuum pipe, I have just checked and it is there and appears in good condition, even the rubber end sleeves! |
Page 1 of 1 | All times are UTC + 1 hour [ DST ] |
