View unanswered posts | View active topics It is currently November 21st, 2025, 12:14 am
Reply to topic  [ 7 posts ]
 Odometer going insane.
Post Odometer going insane.
Right so two weeks ago my speedo was on about 53408, now its 64600, why is the speedo telling me I have done 9000 miles more than I have? although it's giving me an unbelievable mpg I'd rather it be accurate!
June 19th, 2012, 7:08 am
Post Re: Odometer going insane.
Sounds like the magnet inside isn't doing its job correctly?
June 19th, 2012, 8:41 am
The magnet just indicates the speed. The odometer is driven by gears and ratchet and pawl.
John Jordan
June 19th, 2012, 10:05 am
The speed that the odometer turns relative to the wheels is controlled by gears, a cable, and more gears. It's quite possible to see how it could under read if something was slipping, but over reading is very odd. Perhaps if a cog's worn it could be rubbing on the one next door, and bypassing one of the reductions? Whatever, you'll need to take it out for a look, and then replace it if you can't see anything.
Either that, or you need to stop leaving the keys in it.
June 19th, 2012, 11:13 am
Ah of course I forgot about the gears :roll: only had one apart a month or so ago
June 19th, 2012, 11:49 am
what dictates when it turns is there a latch I could have knocked out of position when re paining it ?
June 20th, 2012, 7:30 pm
There are small clips on the digits. Take it apart it's quite interesting..
Don't take the needle or face off though
June 20th, 2012, 9:34 pm
