Lights open warning buzzer.
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4017
Page 1 of 1
Author:  Taskos [ June 12th, 2012, 10:32 am ]
Post subject:  Lights open warning buzzer.
Here is a citroen style "lights open" audible reminder.
The + on the 12V Buzzer goes to the light stalk and the - to the indicators, ignition side as illustrated.
*When ignition on and lights ON then there is 12V both sides of the buzzer and no sound.
*When ignition OFF but lights ON then the buzzer sounds cos there is sufficient current through other components.
*When the indicators operate with lights ON there is also an audible warning.
*The buzzer can be placed between the two stalks or on/below the dashboard.
cheers
Author:  pavlos_k [ June 12th, 2012, 11:20 am ]
Post subject:  Re: Lights open warning buzzer.
Taskos let me get this clear. Is this thing warns you when the lights are open and the switcher is closed, or is it only for the indicators ?
Clever thing if it is for the lights....! Where can i get one ?
Author:  Taskos [ June 12th, 2012, 11:34 am ]
Correct
You can buy a small 12V DC buzzer from any electronic shop for around 1€ I believe.
Then the connections and placing is up to you.
Author:  Sean [ June 12th, 2012, 7:34 pm ]
thats rather good!
Author:  JRW_91 [ June 12th, 2012, 11:22 pm ]
i definitely need to fit something like this to mine... forever leaving my sidelights on when i go into work in the morning... luckily they are LED and she has a Lion heavy duty battery, the original battery did one day go for 8 hours with the original standard sidelights on outside work and she still started but i'd rather not push my luck all the time!
Author:  2CViking [ June 13th, 2012, 9:14 am ]
Rewire the switch through the ignition key.
Author:  J-dub [ June 13th, 2012, 9:34 am ]
All very well until you break down and go for help (assuming you wouldn't leave the ignition on all that time!!)
Author:  2CViking [ June 13th, 2012, 9:50 am ]
Break down... Whats that...!!!
You don't need lights.... What about using hazard blinkers.
Author:  samfieldhouse [ June 13th, 2012, 11:37 am ]
Parking lights ftw 8-) Having had Hetty over a year I still get a thrill from whacking on 'Hawaii five 0' and winking the parking lights ;)
Author:  pavlos_k [ June 13th, 2012, 1:37 pm ]
i did it . only i didnt read the text carefully so when i switch the indicators the audible warning made me wonder what i have done wrong. So coming here to ask i read againg the taskos post and i saw that this is the way it must be .
Thanks taskos for the idea....! now the blinds can hear my car on the stop lights :lol:
The buzzer cost me .5€ and it is with 3 cables .
