 visa air filter
Post visa air filter
Hi guys,
How the hell can I install a visa air filter under the 2cv bonnet?
I've been told the 2cv filter isn't good enough for the 652 engine...
Thanks for your tips :)
June 3rd, 2012, 11:07 am
Post Re: visa air filter
You can use an AX one?
June 3rd, 2012, 1:24 pm
Im no expert but I cant think that an increase of some 10% volume of air would be outwith the ability of a standard air filter - the Dyane have Ami had forced air feed and the filter is the same.....its a very simple design with little air restriction.
June 3rd, 2012, 1:25 pm
Yes you are right a standard 2cv airfilter doesn.t work tried it out
Can.t you put the arfilter overhead the gearbox........
June 3rd, 2012, 2:30 pm
I totally agree - tried all different things with airfilter but the only way the engine would work was with VISA (LNA in my case) along with the valve for cold weather. Without it the thing ran like a dog
June 3rd, 2012, 8:49 pm
OK, above the gear box, but what about the moving gear lever?
I'm trying hard but still far from success... :(
June 3rd, 2012, 11:02 pm
Sorry for insisting on the subject but has anyone got a photo of the right place to put this filter - it is so huge that I can't figure out where to accomodate it...
June 11th, 2012, 12:29 am
This is mine its on a single choke but on the twin choke it fits even better it only needs one support down to the gearbox
June 11th, 2012, 6:50 pm
It looks firm, but the stuff I've got here (the original Visa one) is even bigger and wider...
June 11th, 2012, 10:57 pm
This is something I did many times now, and it works every time! (only solex carburattors)
Put in an original airfilter, and make or buy a turbotube (easily made with 50mm pvc pipe and knees) then change the injector of the first stage of your carb to 125 or 130 (this is the small one) and the injector of the second stage to 125 (this is the big one)
Oh and replace your airfilter with course sponge meterial, this is used for pond or aquarium filters.
I guarantee you it will runn perfect! (if all other things are ok of course!!!)
Greetzzzzzzzzz
Rusty
bitten by the Citobug...
June 17th, 2012, 11:50 pm
