View unanswered posts | View active topics It is currently September 8th, 2025, 5:46 am
 Uneven creaking suspension?
Post Uneven creaking suspension?
Being a mechanical numpty, I have noticed a unsmooth travel in the suspension mainly when cornering (I think mainly on one side), it seems to move a bit then suddenly jolt over with a creeky sort of noise you can feel through the steering wheel. I can feel a simular thing when I park up and the car comes to rest. Does this mean that the knife edges need greasing and if so how and with what do I do this.
Cheers Steve.
June 2nd, 2012, 10:27 pm
Post Re: Uneven creaking suspension?
Could be a dry driveshaft sliding joint. A couple of squirts of grease might cure it.
John Jordan
June 2nd, 2012, 10:34 pm
Bit of veg oil in the cans maybe?
Lack of lubrication may cause the springs to, grind?
June 2nd, 2012, 11:03 pm
I doubt lack of oil in the cans would cause the car to jolt, I could be wrong though. Are the cans damaged? and do they move when the car is jacked up (in a forward to backward motion) ?
June 2nd, 2012, 11:39 pm
Louis your more than likely right. Mis enterperted the word un even ;)
June 2nd, 2012, 11:43 pm
More like a couple of dozen shots, if the driveshafts are really dry. ;)
Working on a car today where the driveshafts hadn't been greased for ages, it took 30 strokes of the grease gun on each side before the middle joint stopped clunking when it was pulled up and down.
June 3rd, 2012, 12:40 am
Ken
Maybe one of these would be a god send
http://item.mobileweb.ebay.co.uk/viewit ... 1144038032
June 3rd, 2012, 9:36 am
Nope,
more like a pita, as it would probably shoot far too much grease in.
You need to be able to feel the slack just go out of the joint.
No good for kingpins either, more chance of popping the Welch plug.
Ken
June 3rd, 2012, 11:33 am
I've not hadone fail, but could te problem be down to a collapsing arm bearing?
June 3rd, 2012, 12:00 pm
Cheers people, I don't think the cans are damaged, but I will try and lube the sliding joints, ta Steve
June 3rd, 2012, 11:57 pm
