View unanswered posts | View active topics It is currently August 27th, 2025, 10:46 pm
Reply to topic  [ 2 posts ]
 Clutch Cable - Your Advice Needed..............
Post Clutch Cable - Your Advice Needed..............
Ive replaced numerous clutch cables in my time BUT Always on 602cc RHD cars without any problems - I have a 74/75 LHD 435cc Car and Im buggered if I can get the tension right on the cable.
Is there a difference in length between a cable on a LHD car or between a 435 and 602 cable ?
Im runnning the cable through the exhaust bracket behind the handbrake and up to the hole in the bulkhead - is this right or should it run behind the suspension stabaliser thing. I have another clutch cable which seems longer than the one im using .
Any advice really welcome - wasted loads of time already and no further forward. Thanks.
May 23rd, 2012, 10:27 pm
Post Re: Clutch Cable - Your Advice Needed..............
I know a LHD cable is about 2cm shorter than a RHD cable if that's any help.
May 23rd, 2012, 10:30 pm
