View unanswered posts | View active topics It is currently November 20th, 2025, 7:24 pm
Reply to topic  [ 5 posts ]
 HOW GOODS YOUR HEATER ?
Post HOW GOODS YOUR HEATER ?
Hi,all my pipe work seams intact,all control cables/flaps seam to be working as intended but the heat is very poor,is this normal for a 2cv :o :?:
May 6th, 2012, 9:51 am
Post Re: HOW GOODS YOUR HEATER ?
When I first started driving my car,I was expecting the heater to be rubbish,but I was suprised how good it was.Even in the winter,with the muff on,it was really hot.
I have fitted new seals to the heater flaps,and have made sure the flaps close properly.
Have you made sure yours are sealing properly?
May 6th, 2012, 10:21 am
Good enough to melt your trainers!
Check that your flaps are opening and closing fully.....
May 6th, 2012, 10:29 am
Some of these paper ducts have foam laid inside.
They may block the air passage.
Also you may:
*Make sure you use the lower airway and not the windscreen demist.(!)
*Place one carton storage box below of each front seat.
*Check the the draft seals behind the central pillars.
I've Been Wrong Before.
May 6th, 2012, 11:08 am
Thanks for all replies,pulled off all pipes today ,all flaps working ok,removed a large piece foam that had lodged in the flap that changes from screen to under dash and it seams to be working alot better,bodged the hose at the mo but will get a new one next week,cheers :D
May 6th, 2012, 6:58 pm
Users browsing this forum: No registered users and 17 guests
