Whine - gearbox, wheel bearing?
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=3915
Page 1 of 1
Author:  J-dub [ May 4th, 2012, 1:06 am ]
Post subject:  Whine - gearbox, wheel bearing?
I have a whine / high pitched noise, it is only audible at 22-26 mph, when not accelerating, but going steadily in gear
It sounds coming from 'up front,
Any ideas as to howi can further my investgation,? ;)
The noise goes away when I depress the clutch pedal, so I geuss it must be gear box'y
Maybe the diff?
I like many have neglected changing the gearbox oil, but changed it with whichever brand viking supplies
Ir was changed say about 4000 miles ago so could do with a change soon
Its not bothering me, id just like to know what it is ......
Author:  Sean [ May 4th, 2012, 7:58 am ]
Post subject:  Re: Whine - gearbox, wheel bearing?
more likley to be input or mainshaft rear
however they all do that
replacement of input means pulling the box apart - the rears there is no harm in taking the back cover off and tightening the nuts on the back of the shaft
the bottom always runs in oil, the diff is massive and well oiled so generally you can rule them out. Main culprits are top rear where it starts to run or the nut loosens allowing the race to become noisy, the input shaft is supported at the other end by the crankshaft pilot bearing, it also has a nylon ball cage which goes brittle with age and can break up - but youd know if that had happened.
oil level is correct? clutch pedal free play correct?
Author:  J-dub [ May 4th, 2012, 8:22 am ]
Clutch pedal correct
Oil level will be checked
Cheers Sean
So nothing to fuss about
I'll take the back cover off and do the tightening when I pull the engine out in a few weeks
Author:  Taskos [ May 4th, 2012, 9:35 am ]
You may try the 80W90 GL-4 transmission oil for quiter running.
Author:  2CViking [ May 4th, 2012, 10:32 am ]
Even banana soup will do :mrgreen:
