View unanswered posts | View active topics It is currently June 19th, 2026, 4:45 am
Reply to topic  [ 4 posts ]
 Electrical woes......
Post Electrical woes......
Not that this bloody 2CV is getting on my tits or anything but, I have some more electrical gremlins.
Having had all the grief with corroded connections and taken them apart one at a time, I now have a situation whereby, when I switch the ignition on, the hazards switch themselves on!
Any ideas?
April 16th, 2012, 10:23 am
Post Re: Electrical woes......
not sure what is ignition switched to that particular piece of Citroen bodgery but as its linked to the indicators which are switched then maybe its something crossed in the link there - the tell tales havent had a live attached to them feeding current back in?
just pull the tell tales, indicator switch etc untill it stops and substitute the switch to eliminate any internal fault
April 16th, 2012, 10:45 am
The hazard switch itself is a problematical bit of kit John. If you have another change it over first to eliminate it.
April 16th, 2012, 11:54 am
Cheers for pointing out the thing I'd bloody overlooked Paul! I've changed one for axactly this fault before in hindsight. :oops:
And, thanks to Sean for posting one to me, everything works just as it should now.
April 22nd, 2012, 8:20 pm
