Kingpin washers/shims
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=3834
Page 1 of 1
Author:  rustygubber [ April 5th, 2012, 10:57 pm ]
Post subject:  Kingpin washers/shims
:?: on kingpins which washers go where,when i took the pin apart there was a single thrust washer on the top and a dust cover one plain washer and 1 thrust washer on the bottom,new kit has 2 plain washers and 1 thrust washer and a dust cover,haynes manual shows no top washer and 2 plain and 1 thrust washer on the bottom under dust cover,scratch head time :|
Author:  Russell [ April 5th, 2012, 11:01 pm ]
Post subject:  Re: Kingpin washers/shims
Any help?
viewtopic.php?f=7&t=1393
Author:  rustygubber [ April 5th, 2012, 11:15 pm ]
Thanks Russel,have already read that but it doesnt mention if all the shims go in the bottom or 1 at the top,cheers!
Author:  ken [ April 5th, 2012, 11:19 pm ]
The photographs here do not show a shim above the arm, though.
Inside the cover, the stack is plain washer, grooved thrust washer, plain washer...
Author:  rustygubber [ April 5th, 2012, 11:34 pm ]
Thanks for reply Ken,are you saying no top washer,all three on bottom with thrust washer sandwiched in the middle of the two plain ones ?
Author:  Sean [ April 6th, 2012, 7:17 am ]
NO top washer they all go at the bottom
Author:  rustygubber [ April 6th, 2012, 8:36 am ]
Thanks Sean,is that the thrust washer in the middle of the 2 plain washers or at the bottom :?:
Author:  rustygubber [ April 6th, 2012, 8:42 am ]
Thanks all,sorted now :D
