Reply to topic  [ 4 posts ]
 Brake system dimensions
Post Brake system dimensions
Ante wrote:
I've forgotten from trade school how to understand, brake pipe internal dimensions in conjunction with master cylinder bore diameter + bore diameter on wheel cylinders. Remember a formular including measured numbers of kg applied to the brake pedal. Anyone here refresh my memory please.
Thanks in advance
March 17th, 2012, 11:14 pm
Post Re: Brake system dimensions
the pipe has little or no effect its the proportion of the master and the slave
5mm master 10mm slave = twice the force at the slave-roughly
you have to calculate the surface area of the pistons (2 X Pi X r1)/(2 X Pi X r2)
Edit (Pi r squared) not working out the circumferance of the pistons as above
March 18th, 2012, 12:51 am
Bit of a random topic, but here you go (with apologies in advance for more than enough Guinness this evening). :roll:
The diameter of the connecting pipework is irrelevant when considering the relationship between the force acting on the master cylinder and the resultant force at the slave cylinder(s).
It's the ratio of the surface areas of the master and slave cylinders which determines the increase in force at the slave cylinders, so if a slave cylinder is 2 times the diameter of the master cylinder, the multiplication factor is 4.
If the slave cylinder has a diameter which is 10 times greater than the master cylinder, the force produced at the slave cylinder is 100 larger and so on...
2CViking wrote:
Thanks in advance
March 18th, 2012, 3:05 am
:? Jesus :?
Why would you want to know that for a 2cv?
March 18th, 2012, 9:36 am
