View unanswered posts | View active topics It is currently May 2nd, 2026, 6:14 am
 When to replace brake disks?
Post When to replace brake disks?
How do you know when to replace them? I guess the obvious answer is 'when braking performance is poor' however I have no comparison. The disks have done at least 60,000 miles (they haven't been changed in my ownership) and there is a noticeable groove in the disk where the pads grip it. She does, however stop fine and received no advisories on it at the last MoT.
Advice/thoughts appreciated.
February 4th, 2012, 7:14 pm
Post Re: When to replace brake disks?
Most manufacturers specify a minimum thickness for brake discs. I'd follow that advice.
Just checked. 4mm. minimum thickness. 0.2mm. run-out.
John Jordan
February 4th, 2012, 7:25 pm
Isn't it also when there rusted to hell or scored badly?
February 4th, 2012, 7:54 pm
The risk is cracking the disc. Seen it a few times, one flying disc removed the caliper from the gear box and became a very expensive repair. Also the risk of loosing all brakes is scary. Replace when the micrometer is reading 4.5 mm
February 4th, 2012, 8:03 pm
Blimey - I guess being the recommended min thickness it will be safe, but 4mm strikes me as being scarily thin :o
February 6th, 2012, 11:33 am
That is Citroens minimum.
All new none Citroen disc have 5 mm stamped on as minimum.
February 6th, 2012, 12:05 pm
given that they come up cheaply on fleabay ill stick new ones on at the drop of a hat, last bunch all used up now so ill have to keep an eye open.
February 6th, 2012, 12:28 pm
The discs on my 2CV have done at least 143,000 miles and there's not much wear (though a previous set of pads lasted over 60,000 and were only replaced due to becoming glazed by age :lol: ).
February 6th, 2012, 12:52 pm
but your car has been in almost constant use?
a car thats been sat up for a while often has glazed rust as the brake surface - ive always found chipping this off and sanding back never gave long lasting results a n.ew set of disks at £35 and you have a good pedal from the word go and a fighting chance of a working handbrake.
February 6th, 2012, 1:09 pm
Viking,
6 sets of discs here, supposedly from 2 different manufacturers, but all stamped with minimum thickness of 6.3mm.
If you compare that with Citroen's recommendation of 4mm minimum, that's the service life reduced by a factor of 4.
Cheeky beggars... :roll:
Cracking is most commonly associated with overheating, but quenching hot discs with (or in) water is a short cut to disaster.
February 6th, 2012, 3:49 pm
