Reply to topic  [ 10 posts ]
 Wheel Jack Upgrade
Online
Post Wheel Jack Upgrade
Any jack's out there with a broken foot. Simple repair can be done....
Select an old bolt and cut off the surplus.
Weld to base of jack
Refit foot, enlarge the hole to allow articulation
Can do the repair on an exchange basis, drop me a pm/email
Useful addition for the old and infirm a cordless drill with 19 mm socket+extension.
January 18th, 2012, 5:06 pm
Post Re: Wheel Jack Upgrade
>wince<
sorry original jacks make me do that
January 18th, 2012, 8:38 pm
Yeh I'm with Sean, I'd rather have intact sills and have to lug around a trolley jack!
January 18th, 2012, 9:19 pm
I've had a couple fail where the little plate that sits in the sill fails and broken off, then the car collapses. The spot welds aren't penetrated at all. Worth a bit of weld on there too.
January 18th, 2012, 9:26 pm
The original jacks scare me...some of the most rusty bits of a 2CV seem to be the original Jacking points. I personally carry a bottle jack and a few selected bits of wood (one that goes underneath it in case of mushy ground and one one top to give the height) that will just raise the car for a wheel change on the roadside. I would only ever jack the 2CV on a chassis section even in roadside emergancy.....no matter how good or new the sills are.
At home I only ever use a decent trolley jack on the decent bits of chassis. In fact I have a lump of wood that spans the chassis and use that plus stands.
January 18th, 2012, 9:44 pm
i jack the arm much less comedy value as you dont pump away till its lurching like an Italian Cruise ship yet the wheel stays on the ground.
January 18th, 2012, 9:48 pm
What Sean said!
really fast tyre changes, when no trolley jack around
January 18th, 2012, 9:52 pm
I can't get trolley jacks under my cars. Factory jack and battery drill/posh nut runner are all I can use, unless the forklift is handy.
January 18th, 2012, 10:05 pm
I've never used the original jack, I have one in mint condition, but I'd only ever use it for hitting my brother or something, I wouldn't feel confident jacking the weight of the car on the sills!
January 18th, 2012, 10:36 pm
Russ:
just as low as your cars ;)
January 18th, 2012, 10:37 pm
