Reply to topic  [ 25 posts ]  Go to page 1, 2, 3  Next
 lights... or lack of
Post lights... or lack of
rightiooo, no dip beams, checked the usual, all ok. soooo, anything i've not thought of or any other ideas, i'm thinking maybe relay or switch mechanism? (replaced before salbris)
December 16th, 2011, 11:09 pm
Post Re: lights... or lack of
What age is the wiring in that thing? Have you got the dim-dip stuff on it? Actually that's a silly question, I'm sure Spanners wouldn't have fitted it, or would have binned it if someone else had. In which case if you've got relays, then it's a bit modified and hard for us to guess. Any more clues?
December 16th, 2011, 11:19 pm
wiring is from a mid 80's saloon i believe, so yes, relays dim dip etc, i have only sidelights and high beam (incl spotties)
December 16th, 2011, 11:23 pm
It's probably a bad connectiOn on the relays or a duff relay
December 16th, 2011, 11:27 pm
Had exactly the same thing the other week. Its the relay. £4.27 off ecas, but one that's next to the battery as opposed to the one that you might have on the front of the chassis rail? Something like that anyway. Or I may be talking bollocks.
December 16th, 2011, 11:39 pm
cool, got relays so ill swap tomoz
December 16th, 2011, 11:44 pm
Check to see if the dipped beams come on at reduced intensity with the sidelights when the ignition is on, as they should. If they do, then I'd put my money on the 5 wire relay being at fault.
December 16th, 2011, 11:55 pm
The real question is,
why is anyone still running around with the perishing dim-dip system still hooked up when it's been mentioned repeatedly that it _will_ damage the light switch? :?
Get rid of the relays near the battery, whatever remains of the resistor on the front of the chassis and also the diode cable tied to the flasher unit, then fit a short 'jumper' lead on the 5 pin relay plug and job's a good one... :)
Jumper lead to bypass dim dip by slcchassis, on Flickr
December 17th, 2011, 12:02 am
>nods head vigorously<
bin everything to do with dim dip
December 17th, 2011, 12:24 am
LOL. One day I'll post on a technical thread and actually not be talking garbage, promise...
December 17th, 2011, 2:25 am
