Page 1 of 1
[ 5 posts ] |
J-dub
 Manifold removel
Right, on my dyane engine the manifold came off easy peasy lemon squeezy On my car, that's not going to be the case, I've got a nut splitter, has anyone used one on a manifold nut? What where the results Would it be best to buy a stud extractor too and renew the studs, or would that cause more grief? Just getting the nut on will be interesting! Reason I ask is I'm renewing the oil feed pipes soon, and seeing as I have the cowling off I might as well get the rubber shrouds off in favour off some metal tinny's
| November 8th, 2011, 10:30 am |
 Re: Manifold removel
sharp chisel split the other nuts off by Sean602, on Flickr dont take the studs out unless they are too far gone as they will be corroded at the other end, this drags up through the thread as you unscrew them and may cause damage to the threads in the ally resulting in weak or wobbly studs. brass nuts shakeproof washers and lots of copper grease on re assembly- jobs a goodun.
| November 8th, 2011, 10:45 am |
J-dub
Duely noted
| November 8th, 2011, 10:48 am |
Joolz
The 'Search' tool is your friend, viewtopic.php?f=7&t=2609In case you can't be arsed to go and read it, Joolz wrote: If the exhaust nuts feel like they don't want to move, DO NOT keep applying more torque until the stud breaks, it will be your free pass to a whole world of pain.
Much better to destroy the nut getting it off, either splitting it with a chisel as Ken(or in this case Sean) said, cutting one side off with a grinder or hacksaw, or drilling into it to weaken it before knocking it off with a chisel.
Even when it looks realy crusty from the outside, the thread under the nut is usually quite serviceable, so don't try and get the studs out unless they come out on their own. Minor damage to the thread isn't too much to worry about, it can be cleaned up afterwards with a die nut.
DO NOT BREAK THE STUD! I've got some pictures to go with this but they're not in my photobucket, must be still on the camera.
| November 8th, 2011, 10:48 pm |
J-dub
Cheers joolz I will read it
| November 8th, 2011, 11:17 pm |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 102 guests |
