View unanswered posts | View active topics It is currently November 21st, 2025, 2:06 am
Reply to topic  [ 26 posts ]  Go to page 1, 2, 3  Next
 Calibrating 2cv speedo
Post Calibrating 2cv speedo
The speedo over reads, is there a way to calibrate it at all?
I had to take it apart and put needle back on at zero but spring must have adjusted?
I believe it's 'cos I haven't wound the spring up correctly when I stuck the needle back on?
I'd liketo get it spot on again!
Advice much appreciated
November 7th, 2011, 1:28 pm
Post Re: Calibrating 2cv speedo
take it off and put it back on at less than zero?
( think it had an element of Preload) beyond that its not something that i fiddle with as they never go wrong.
November 7th, 2011, 2:10 pm
Hmm
If I took the face off, took needle off got up
To 30 using satnav, and then stuck needle on at 30
That should work?
November 7th, 2011, 2:48 pm
why did you take it off in the first place?
for the record - I don't recomend driving at 30mph whilst keeping an eye on the satnav and trying to refit a speedo on a 2cv dash and maintaining your speed :?
November 7th, 2011, 3:30 pm
I wasn't planning on using an open road to do that
Was going to use the yard at work!
Anyone got a useable one?
November 7th, 2011, 3:38 pm
sigh
take glass off turn the mech on the back till the needle reads 15mph take needle off and replace to 0 release the mech?
or do it your way and win the Darwin award :lol:
November 7th, 2011, 3:42 pm
No don't stop him I wanna hear about it on the news :lol: :lol: :lol:
November 7th, 2011, 5:44 pm
Well
The Darwin method was spot on although because on stupid I felt 3mph wasn't accurate enough (it was 3moh under reading vs the gps speed, so I took needle off. I did it whilst driving 20mPh but realisticly you need a cute blonde on your lap to drive whilst you put needle on. It worked. Waiting for the yard at work to clear before I do it!
November 7th, 2011, 6:33 pm
Would increasing the tyre pressures have been too simple?
November 7th, 2011, 8:04 pm
How would that work?
As I drove home I removed te needle and replaced at correct mph. Going to use sat nav to check. Use a speedometer app on my iPhone originally.
All is good
Now how to thread I'm arras ;)
November 7th, 2011, 8:12 pm
