View unanswered posts | View active topics It is currently May 2nd, 2026, 3:42 am
Reply to topic  [ 3 posts ]
 Head Torque....
Post Head Torque....
Should i torque the heads as a matter of course? good or bad idea...
www.evilbens.blogspot.com
November 5th, 2011, 6:05 pm
Post Re: Head Torque....
Depends what you mean by torque the heads - they certainly should be checked occasionally and torqued up to the correct torque of 2.0 - 2.3 kgm - 14-17lbft.
I believe you are supposed to back them off first then tighten up to the correct figures.
The sequence is Upper Front, Upper Rear then Lower Nut.
November 5th, 2011, 6:32 pm
Ben,
its not really necessary as a regular maintenance thing but wont do any harm to do them now so you know they are right. Crack off the nuts by 1/4 turn and re tourque as above.
Do you do engine work or is it all body work stuff on the VWs?
Do you still get the steel shims/head gasket things with recon heads or the recon engines ? if so do you have any 1600 ones you havn't got round to putting in the bin?....they are a perfect fit on the base of Citroen barrels for making low comp engines.
I had a box of them but gave some away and binned the rest when i stopped messing with VWs
November 6th, 2011, 10:42 pm
Users browsing this forum: No registered users and 85 guests
