Reply to topic  [ 8 posts ]
 confusing cutting out
Post confusing cutting out
My car occasionally cuts out,
its random, Chris and I thought it may be due to the fact id been puting high octane fuel in, so I have been putting normal stuff in, but not much, and its been fine, admitedly id let the tank run v low yesterday so may have been some left of the high octane stuff, and some got through but it cut out, and no power on the ignition (almost like a complete eletrical failure, fuel gauge, oil pressure light, and indicators, dead, as if the ignition was off..)
so at this point im doing 20mph entering a roundabout, so an ideal situation really, so dumped in 2nd and dumped clutch to bump start, wouldnt go (thats when i realised ignition dead) so turned key to the off position, and back to the ignition on position, did the 2nd gear dump clutch procedure and it fired up and went straight away, without a problem,
Dodgy ignition barrel maybe? i recently had to spray wd40 down there to free the lock off, thinking of maybe bypassing the ignition switch for some testing to see if it is this, but anyone come across this before?
annoyingly its not the sort of thing i can mimic to see if its still happening
October 16th, 2011, 12:20 am
Post Re: confusing cutting out
James,
98 octane fuel will not make your engine cut out, but a dodgy ignition contact drum could do.
October 16th, 2011, 12:37 am
James,
Ok I'll have a playThanks ken
October 16th, 2011, 9:15 am
James first part of post if flawed - higher octane petrol and lower wont just sit as 2 layers in the tank like some fancy cocktail - :lol:
think you have answered your question in the 2nd half ;)
October 16th, 2011, 12:11 pm
Think I have
Yesterday when cranking car wouldn't start, as soon as I let the key into the running position it fired up
Dodgy contacts,
Are they removable and cleanable?
October 19th, 2011, 3:56 am
Think I have
Dodgy contacts,
The contact drum pulls off the bottom of the lock assembly. It's a 120 second job to replace it.
October 19th, 2011, 11:24 am
it was so easy to do, done it in a jiffy,
we will see how things run from now on :)
October 23rd, 2011, 10:27 pm
Well.
Ran it for a week without any stupid cutting out as before.
Hopefully problem solved
October 29th, 2011, 7:22 pm
