 Whats going on in my bush, or is it brush? There's no leccy!
Post Whats going on in my bush, or is it brush? There's no leccy!
James Wallace kindly took me home last night and then we spent a fun time in his work's workshop fitting a new alternator. What do you make of this:
This would be why it wasn't charging then!
How it should look:
October 9th, 2011, 6:18 pm
Post Re: Whats going on in my bush, or is it brush? There's no le
Hey,I've got one of those forks,a very important part of my tool kit :lol:
October 9th, 2011, 6:28 pm
Looks like you need to have a serious look at the state of the slip rings in the alternator
October 9th, 2011, 6:29 pm
Sam,
I've seen this happen a few times with Iskra alternators, one fellow managed to break one of the brushes when installing a replacement set, then spent half a day chasing round everything else in the charging system on the basis that there couldn't be anything wrong with the alternator. :(
It might be an idea to remove an Iskra alternator from the car when fitting a new brush set, to reduce the chances of having the one or even both of the brushes sitting at an angle...
@250, there is a gap between the slip rings, which is why that brush wore as it did.
October 9th, 2011, 9:03 pm
we bunged the hole alternator in, in the end
sam was on his way fine again after a bit of charge in to battery and a coffee
i had to push start him at the petrol station whilst towing my old chassis, quite difficult to push a 2cv with a trailer on !!
October 9th, 2011, 9:28 pm
Long set of jump leads of your monster battery would have powered both cars drive in convoy ;)
October 9th, 2011, 9:44 pm
sam wanted to get the leads out to jump his car but id rather just push it :lol:
October 9th, 2011, 9:45 pm
I'll get the old alternator serviced, or will it have had it?
October 10th, 2011, 2:12 am
Those brush packs dont look the same
what alternator is in the car ?
if its a Ducellier or the other one with the internal fuse pop the black cover off and have a look to see if one of the tracks has gone
October 10th, 2011, 8:08 am
There both iskara
October 10th, 2011, 8:46 am
