 Shock absorber mount
Post Shock absorber mount
Has anyone seen this happen before put new shocks on about 3 weeks ago then today heard a bit of a creaking noise had a look underneath and found this any ideas how and why its happened?
IMAG0441 by Chris 2cv, on Flickr
September 29th, 2011, 10:10 pm
Post Re: Shock absorber mount
Yes often seen on raid cars. Welding should fix that problem
September 29th, 2011, 10:12 pm
I've got a spare one so will chuck another on just trying to work out how I managed to break it!!!
September 29th, 2011, 10:19 pm
shocker plates on the wrong way round?
September 29th, 2011, 10:23 pm
Chris,
if I'm not very much mistaken, your damper mounting plates have been swapped over, which would explain why things fell apart...
Front damper plates swapped side to side... by slcchassis, on Flickr
September 29th, 2011, 10:27 pm
Aha Thanks Sean and Ken I shall have a good look at my other 2cv tomorrow and check which way they are fitted on that. They must have been the wrong way around on this for ages as I've only ever taken them off one side at a time!!!!
September 29th, 2011, 10:35 pm
makes no odds what the other one is doing those ones are wrong ;)
September 29th, 2011, 10:41 pm
Yes, I also think that it is left on right and right on left...
www.2cvkeza.com
September 30th, 2011, 1:43 pm
You were all spot on swapped round and alsorted now. Many thanks peoples!!!!
September 30th, 2011, 8:52 pm
Does it handle any better? ;)
September 30th, 2011, 9:01 pm
Users browsing this forum: No registered users and 119 guests
