Sidewinder Engine Mounts
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=3362
Page 1 of 1
Author:  Nelsthebass [ September 27th, 2011, 7:22 pm ]
Post subject:  Sidewinder Engine Mounts
Anyone know what I use to replace Nippys engine mounts? - ripped them off dropping the clutch today!
I believe that you have to cut GS mounts down but whats the story on that?
Cheers
Paul
Author:  Tim2cv [ September 27th, 2011, 8:20 pm ]
Post subject:  Re: Sidewinder Engine Mounts
Hi,
I thought I had one marked up pre-mod but I cannot find it sadly. (will keep an eye out though when in the garage!)
I have taken some pics of mine though (bad ones that are not very useful). Ignore the square steel spacers as these were put in to get the height up enough to clear the steering rack for fitting a 5 speed box.
Front the front underneath
Mystery Mount
Mystery mount and mystery mount no2
sorry I'm not much help, will keep looking for my template!
Author:  spanners [ September 27th, 2011, 11:10 pm ]
Mystery mount number 1 is Ami Super.
Mystery mount number 2 is GS/A.
I modified a pair of GS/A ones (dodge business that was!) but, if you still have the remains of the old ones, there are people that re-rubber them for you. Failing that, try Robb Moss at the Chevronics centre.....
Author:  Joolz [ September 28th, 2011, 1:01 am ]
Hi, I've no experience with these, so it's just a thought. If the set you've broken are the same as the ones in Tim's pics could you re-use the top part and bolt it onto a 2cv mount, or even make a bracket to go on the top of a 2cv mount from a piece of angle iron. Or are the 2cv mounts too soft.
Author:  spanners [ September 28th, 2011, 8:24 am ]
Either way, they're gonna be a whole lot better than no engine mounts!!
Author:  Nelsthebass [ September 28th, 2011, 9:08 am ]
Cheers Guys - looks like you have to cut part away of a GS mount to fit past the discs.
Author:  spanners [ September 28th, 2011, 11:32 am ]
It's not the discs you have to worry about, they'll smash the Ami Super bellhousing first!
