Reply to topic  [ 8 posts ]
 Best stuff for rustproofing a chassis
Post Best stuff for rustproofing a chassis
With winter coming on, and having decided to keep the Ami as my everyday car, I've decided that rustproofing and painting the chassis and underside of the cab would be a good idea. Problem is, there's a bewildering variety of products out there, all of which seem to attract roughly equal numbers of people saying they're the best things since sliced bread, or rubbish. What do you lot use?
September 26th, 2011, 5:36 pm
Post Re: Best stuff for rustproofing a chassis
I've been advised that epoxy paint (I'll provde link later) is good
Used on oil rigs too don't you know ;)
September 26th, 2011, 6:57 pm
This is the best stuff I've used (by miles):
You can buy it, and associated products, here. It's also on ebay.
September 26th, 2011, 7:31 pm
Bilt Hamber Dynax S50 is excellent for protecting cavities
http://www.bilthamber.com/pro-introduct ... =Corrosion Prevention&name=dynax S50
September 26th, 2011, 10:03 pm
:D t'is
pic:Image
this is what my citroen mechanic uses, epoxy mastic
September 26th, 2011, 10:11 pm
You beat me to it!!! I was going to ask exactly the same thing.....I was reading up on Waxoyl the other day too, on piston-heads forum. Doesn't get a good press at all....some reckon it's best avoided so you can see where / if the rust is coming through rather than hide it.....i buy that logic
also, given up on stopping leaks into the foot well - gonna get my drills out and make some drain holes....
September 27th, 2011, 11:37 am
The chassis' rust from the inside out, not the outside in. It's impractical to paint inside a chassis. A rust proofing wax, properly applied, will prevent that type of corrosion. Epoxy primer is good stuff, but it is for protecting the outside of the chassis, in my view there isn't a single solution to prevent rusting. You need to exclude water, prevent moisture and oxygen get to the metal, don't allow dirt that holds moisture to build up.
I tend to thin the initial application of rust wax with Duck oil to help carry it into the seams.
September 27th, 2011, 12:10 pm
I know this. Hence "rustproofing and painting the chassis ... ;)
September 27th, 2011, 2:50 pm
Users browsing this forum: No registered users and 119 guests
