View unanswered posts | View active topics It is currently May 2nd, 2026, 2:06 am
Reply to topic  [ 2 posts ]
 AK 400 panels
Post AK 400 panels
Norman wrote:
John had bought the repair panels from SPOG and as there were no instructions provided, this was the only arrangement we could find in which they would fit.
There was no chance at all of it fitting as shown on Roy's picture.
It doesn't fit because the panel is the wrong size. It should be square which is what is in the ECAS picture and the original we removed. See picture showing original outlined in white.[/quote]
My turn to be in trouble. Just got these panels from SPOG but they just don't fit.
Thanks to Janez I'll fit his well made panel. http://2cvkeza.weebly.com/2cv-au---azu---ak.html
September 11th, 2011, 7:46 pm
Post Re: AK 400 panels
Had to cut the vertical face and weld it back together, allowing it to slide in between the chassis and cargo floor. Just be aware when ordering this repair panels when rebuilding the rear cross member.
Also slightly shorter than original but that doesn't matter much.
Couldn't use the panel from Janez, the AZU is not the same as AK (cargo floor and chassis is shorter)
September 13th, 2011, 6:44 pm
