View unanswered posts | View active topics It is currently May 2nd, 2026, 3:36 am
 lamp bar shortening
Post lamp bar shortening
Howdy, I want to shorten my lamp bar to pre square headlight spec, anyone got measurements, how much to shorten it by? I would just try and figure it out but I have no bonnet, only one wing and the car is in a million pieces.
Thanks!
September 4th, 2011, 6:41 pm
Post Re: lamp bar shortening
Thanks!
6 cms each side
September 4th, 2011, 6:48 pm
I shortened mine by 30mm each side.
September 4th, 2011, 8:18 pm
Is that a half measure or just to be that bit different
September 4th, 2011, 8:28 pm
Ok thanks, so 6cm each side? seems alot more than I was thinking, will that work fine with 2CV6 bonnet? Russell, do you have a photo of yours with the 3cm shortened bar?
September 4th, 2011, 8:46 pm
Just measured them. From the rotating bracket to the where the lamp holder is welded on is 12 cms on a modern light bar and 6 cms on an older one. Both cars have standard bonnets.
September 4th, 2011, 8:55 pm
Photos of my car in the red spesh thread. I cut the weld off the bar and slid them up and down until it looked right.
September 4th, 2011, 9:20 pm
I shortened mine 80mm one side and 60mm the other, the bonnet dont close too well.
September 4th, 2011, 9:35 pm
Thanks all, I think I'll be patient and wait til I can test it in position, but I reckon the 60mm will be right.
September 5th, 2011, 7:54 pm
Might be an idea to leave some extra leeway, as I'm sure I recall having to be ease the bonnet between the headlights on a 1963 van which still had the original light bar fitted...
September 5th, 2011, 8:08 pm
Users browsing this forum: No registered users and 103 guests
