Replacement sills
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=3301
Page 1 of 2
Author:  rustygubber [ September 6th, 2011, 9:51 am ]
Post subject:  Replacement sills
Anyone fitted sills from 2cv city,they seam the best priced ones i have found
so far,just wondered what the quality is like :?:
Author:  Lenny [ September 6th, 2011, 10:50 am ]
Post subject:  Re: Replacement sills
If I remember rightly they do two qualities.
The cheaper ones came without seat belt mountings so I bought the more expensive ones.
They fitted as well as any other non-genuine panel ie they took a bit of persuasion here and there but basically they were fine.
Author:  Sean [ September 6th, 2011, 11:07 am ]
old car has no seatbelt mounts on the sills
newer has them fitted
its a pain trying to get decent mounts fitted to non mount sills and, unless your good, would you trust them in a bump?
as for the quality of City supplied ones i cant say as i never use them
Various manufactured sills had various issues - too long, too narrow, not enough rocker etc and all needed a degree of skill/experience to fit properly.
A Red coated set from the other main supplier were by far the best ive used.
Author:  rustygubber [ September 6th, 2011, 9:16 pm ]
Thanks for replies :D
Author:  twofifty AZU [ September 6th, 2011, 9:22 pm ]
Check the wing mount stud, I've had several sills where it's been positioned way off.
Author:  Russell [ September 6th, 2011, 9:41 pm ]
Buy from ECAS. Roy only stocks and sells what he feels is best quality, not best price.
Author:  rustygubber [ September 7th, 2011, 9:16 pm ]
Ok thanks for tips,are the early sills the same as the late ones,except for seat belt holes :?: anyone :)
Author:  Sean [ September 7th, 2011, 9:19 pm ]
yes but if you have a car with belts dont bother, pay a bit more and save yourself a whole heap of trouble ......trust me!
Author:  2CViking [ September 7th, 2011, 9:21 pm ]
The same but stay well clear of them (depending on where produced) They are badly made and very thin. Use modern sills and ignore the belt holes.
Author:  spanners [ September 8th, 2011, 7:57 am ]
I'm sure it's been rectified in the years since but, the last (and only) time I had a pair of sills from "Up North", the seat belt mounts had M10 threads in and not the correct imperial thread for seatbelt bolts rendering them absolutely bloody useless!
I ended up cutting them open and welding the correct mounts into them as I'd not bothered to check them before welding them in! :evil: :evil:
