 Replacement sills
Post Replacement sills
Anyone fitted sills from 2cv city,they seam the best priced ones i have found
so far,just wondered what the quality is like :?:
September 6th, 2011, 9:51 am
Post Re: Replacement sills
If I remember rightly they do two qualities.
The cheaper ones came without seat belt mountings so I bought the more expensive ones.
They fitted as well as any other non-genuine panel ie they took a bit of persuasion here and there but basically they were fine.
September 6th, 2011, 10:50 am
old car has no seatbelt mounts on the sills
newer has them fitted
its a pain trying to get decent mounts fitted to non mount sills and, unless your good, would you trust them in a bump?
as for the quality of City supplied ones i cant say as i never use them
Various manufactured sills had various issues - too long, too narrow, not enough rocker etc and all needed a degree of skill/experience to fit properly.
A Red coated set from the other main supplier were by far the best ive used.
September 6th, 2011, 11:07 am
Thanks for replies :D
September 6th, 2011, 9:16 pm
Check the wing mount stud, I've had several sills where it's been positioned way off.
September 6th, 2011, 9:22 pm
Buy from ECAS. Roy only stocks and sells what he feels is best quality, not best price.
September 6th, 2011, 9:41 pm
Ok thanks for tips,are the early sills the same as the late ones,except for seat belt holes :?: anyone :)
September 7th, 2011, 9:16 pm
yes but if you have a car with belts dont bother, pay a bit more and save yourself a whole heap of trouble ......trust me!
September 7th, 2011, 9:19 pm
The same but stay well clear of them (depending on where produced) They are badly made and very thin. Use modern sills and ignore the belt holes.
September 7th, 2011, 9:21 pm
I'm sure it's been rectified in the years since but, the last (and only) time I had a pair of sills from "Up North", the seat belt mounts had M10 threads in and not the correct imperial thread for seatbelt bolts rendering them absolutely bloody useless!
I ended up cutting them open and welding the correct mounts into them as I'd not bothered to check them before welding them in! :evil: :evil:
September 8th, 2011, 7:57 am
Users browsing this forum: No registered users and 119 guests
