| Engine Compression http://international2cvfriends.com/forum/viewtopic.php?f=7&t=3266 |
Page 1 of 5 |
| Author: | james2cv [ August 23rd, 2011, 9:56 pm ] |
| Post subject: | Engine Compression |
Ok did a compression test earlier, one side was reading 165 and the other just under 140. Engine was warm and there's nowt wrong with the battery or starter. I know that 140 it abit low but not very very low... It's the big difference that's a bit more worrying? Time for new pistons and barrells in the not too distant future or should I not worry until it blows up or something? Cheers, J |
| Author: | Sean [ August 23rd, 2011, 10:02 pm ] |
| Post subject: | Re: Engine Compression |
adjust the tappets first then start worrying or carry on worrying...whatever Sean |
| Author: | twofifty AZU [ August 24th, 2011, 1:03 am ] |
After you've adjusted the tappets if the readings are still uneven do a "wet" compression test. Put a bit of oil down the bore and test. If there is no change you have a leaky valve. If the compression goes up it was getting past a piston. |
| Author: | Devils Advocate [ August 24th, 2011, 12:57 pm ] |
'They' do say that having a large difference is more significant that just, say, both being low. I don't actually know why that is... But, my tuppenth worth is that 140 psi ain't that low at all, and 165 is pretty damn hot. I bet your car is running just fine? It ain't going to blow up, and I'd suggest that no new barrels and stuff is needed for a goodly long time. |
| Author: | Sean [ August 24th, 2011, 1:41 pm ] |
you want all the cylinders in a multi cylinder engine working the same - a high reading on one may indicate a wet bore or incorrect valve gaps and would need investigating,- low indicates wear, leaks or burnt valves - again worth investigating. on a 2 cylinder there is no mean which to compare the readings, but there is a "healthy range", and its nicer to have a well balanced engine. simplest and most probable is tappet clearance first to see if the high side drops or the low side comes up. Then leak down or oily test ( not as reliable on a horizontal engine)to see where the low side is loosing out. good side is good poor side is at low end of what id be happy with but as long as its not blowing all its oil id not loose sleep over it Sean Keep on worrying those toads Quote: 'They' do say that having a large difference is more significant that just, say, both being low. I don't actually know why that is... |
| Author: | ken [ August 24th, 2011, 3:17 pm ] |
On the other hand, if everything else with the engine was OK, those figures could suggest that there was an 8.5:1 piston in one side and a 9.0:1 in the other. It does sound crazy, however it has been known to happen. No, it wasn't at all hot and it did not run well... ken Devils Advocate wrote: 'They' do say that having a large difference is more significant that just, say, both being low. I don't actually know why that is... But, my tuppenth worth is that 140 psi ain't that low at all, and 165 is pretty damn hot. I bet your car is running just fine? It ain't going to blow up, and I'd suggest that no new barrels and stuff is needed for a goodly long time. |
| Author: | Sean [ August 24th, 2011, 3:37 pm ] |
ken wrote: On the other hand, if everything else with the engine was OK, those figures could suggest that there was an 8.5:1 piston in one side and a 9.0:1 in the other. It does sound crazy, however it has been known to happen. No, it wasn't at all hot and it did not run well... ken one of Norrys engines had that set up Harper took great delight in pointing out why it "ran a bit lumpy" |
| Author: | james2cv [ August 24th, 2011, 3:54 pm ] |
Yes, the engine pulls fine really considering its the original 8:5:1 set up as far as I know. It doesn't use huge amounts of oil and will sit at 70 (ok 55 up hills) all day when it isn't pinking |
| Author: | Sean [ August 24th, 2011, 4:05 pm ] |
james2cv wrote: Yes, the engine pulls fine really considering its the original 8:5:1 set up as far as I know. It doesn't use huge amounts of oil and will sit at 70 (ok 55 up hills) all day when it isn't pinking Ah see thats the sort of info we need could well be a scuffed barrel or nipped ring now when will you lot learn the importance of proper timing why not get someone to do them properly DURING Snet? there will be lots of time for that sort of crap fri and sat morning and there will be enough people around who know how to use proper tools to set the ignition up tip top. Sean |
| Author: | james2cv [ August 24th, 2011, 4:17 pm ] |
Sean wrote: james2cv wrote: Yes, the engine pulls fine really considering its the original 8:5:1 set up as far as I know. It doesn't use huge amounts of oil and will sit at 70 (ok 55 up hills) all day when it isn't pinking Ah see thats the sort of info we need could well be a scuffed barrel or nipped ring now when will you lot learn the importance of proper timing why not get someone to do them properly DURING Snet? there will be lots of time for that sort of crap fri and sat morning and there will be enough people around who know how to use proper tools to set the ignition up tip top. Sean Oops. |
| Page 1 of 5 | All times are UTC + 1 hour [ DST ] |
