Reply to topic  [ 3 posts ]
 Rear wheel cylinders question...
Post Rear wheel cylinders question...
Hi All
I've discovered some new, but unboxed 2cv rear brake cylinders whilst rummaging in the garage. Is there any visual way of telling whether they are LHM or Dot-4 ones? Two have green dust covers so quite obvo lhm but the rest are all identical in black. Any info would be appreciated.
Thanks!
Will
1979 2cv6 (Evie)
1983 Beachcomber (Mavis)
1991 AXGT Mk1
2008 C5 2.0 HDi VTR+
August 19th, 2011, 10:19 am
Post Re: Rear wheel cylinders question...
Check the bore size?
Should be 17.5mm for drum brake type, with pipe nut thread of 8mm x 1.25mm for the later ones, plus the seals are usually cup type and there's a small spring between the seals.
Will2cv wrote:
Hi All
Thanks!
Will
August 19th, 2011, 11:05 am
As far as I know
green dust covers = LHM
black dust covers = Dot4/5
August 19th, 2011, 12:30 pm
