Reply to topic  [ 5 posts ]
 battery wont hold its charge
Post battery wont hold its charge
Hey everyone,
Does anyone have a simple solution for the battery not holding its charge??? Is it the alternator or voltage regulator?? Its on a 1984 2cv6 special Beachcomber.
Jack
August 16th, 2011, 9:27 am
Post Re: battery wont hold its charge
Barkerjack01 wrote:
Hey everyone,
Jack
If the car is charging [simple test, do the headlights get brighter when you rev the engine] then the simple solution is to buy a new battery.
August 16th, 2011, 9:48 am
No they dont.
I had the battery on charge last night - via an external charger - and just started her up and checked everyything, all is working in and out. But the lights dont get brighter when the engine is revved. Plus the battery is only 2-3 months old.
Anymore easy tests/fixes????
Jack
August 16th, 2011, 10:03 am
Barkerjack01 wrote:
No they dont.
Jack
Do you have a multi meter to test the output of the alternator. The likelihood is that the brushes have worn out in the alternator. On most alternators this is a cartridge type affair which can be removed with one or two screws at the back of the alternator. Cheap as chips to buy.
August 16th, 2011, 10:12 am
i dont, but am taking it to a local garage in the next 30 mins, so ill tell him what you've said and he'll sort it out. hopefully.
Ill tell you if i do!
August 16th, 2011, 11:45 am
