Page 1 of 1
[ 5 posts ] |
Numpty question....Continued
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
OK, I know this is going to come across as a very simple, stupid question.....
what size is the nut on the exhaust manifold? 10mm won't look at it and 11 is as sloppy as a sloppy thing. its a little rusty so I'm assuming its probably a worn 11mm ......
I have a pretty comprehensive tool collection both imperial and metric, but I'm finding the 2cv uses some funny sizes....
cheers gerry
| July 16th, 2011, 11:39 am |
Russell
 Re: Numpty question....
It *was* 11mm but after years of getting hot/cold and rusting away it won't be any more.
Welcome to the world of M7 and M9 threads, and 11mm bolt heads.
| July 16th, 2011, 11:47 am |
It was an 11
dont be tempted to try to un screw it itll end in tears
sharp chisel and split it off.
| July 16th, 2011, 11:50 am |
48pop
ok, so now its off.......Should I replace the studs or leave well alone? The exposed threads are knackered but obviously the bits where the nut was is fine......(this is all on the spare engine btw)
| July 16th, 2011, 3:05 pm |
 Re: Numpty question....Continued
Id be tempted to leave it.
the back of the stud is exposed and so when you use the mole grips( because there isnt enough to get 2 nuts on it to lock it, alternative is to put an M8 or 10 nut over the stud and weld it up-removing the stud while the area is still hot) to turn it out you drag the corroded end through and it rips up the thread.
I always have a helicoil on standby when taking the studs out.
Brass M7 available from ECAS and lambretta supplies, lots of copper grease on assembly
| July 16th, 2011, 3:16 pm |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 113 guests |
