Reply to topic  [ 47 posts ]  Go to page 1, 2, 3, 4, 5  Next
 slowbo no run , job done all sorted
Captain Slow
Post slowbo no run , job done all sorted
so iv got the 2cv out afther 14 months
put new battery , spark plugs ,ht leads and coil .new fuel filter
it fired up then died , think its the carb , fuel is going in , it was running fine 14 months ago ,must not have not liked it in the grage :lol:
what do i need to check ??
July 11th, 2011, 9:04 pm
Post Re: slowbo no run
oboe,
when you laid it up, didn't you put some oil into the cylinders?
Until that's all gone, it will keep fouling the spark plugs, so take the plugs out and spin it over on the starter with the throttle wide open.
Put some old rags in the firing line to soak up any oil that's ejected from the plug holes.
Next. make sure that petrol is getting to the carb.
If it isn't, remove the fuel pipe at the carb, take a deep breath and blow down the filler neck until fuel emerges from the pipe.
Hook the pipe back onto the carb, fit your old plugs and try starting it.
If that doesn't work, clean the oil off those new plugs by heating them in a gas flame, then pop them back in and repeat as necessary until liftoff is achieved... ;)
July 11th, 2011, 9:52 pm
Captain Slow
yep i did what u said , when i put it to rest , guess it's oil on the spark pugs .
il have a go 2moro
cheers ken
July 11th, 2011, 10:04 pm
Try this
July 11th, 2011, 10:17 pm
when you laid it up did you also run it with the fuel pipe disconnected and use all the fuel up in the carb? unleaded doesn't like being left for a long time it will evapourate and leave a sediment in the carb possibly blocking the jets.
July 12th, 2011, 11:18 am
Have you got fresh fuel in the system?After 14 months the fuel will have " gone off ". Empty the tank and try fresh fuel if you havent already.
July 12th, 2011, 12:27 pm
I hear on the grape vine that Uncle Steve is on his way to help, don't let him use a hammer Obeo. ;)
July 12th, 2011, 4:32 pm
Captain Slow
ok so still no run
had carb apart and clean out
new battery on
got a spark on both plugs , coil is ok
got 123 on , put points on and still didnt work
fuel is getting to the carb and is fresh new fuel
if we pour fuel in top of carb it runs then dies
not sure what to look for now
July 12th, 2011, 8:41 pm
Idle jet missing. Try gravity feeding the carby to eliminate fuel pump etc.
July 12th, 2011, 10:16 pm
Well, it's clearly a fuelling fault, so that's narrowed it down!
The most likely candidates I think are: fuel pump not supplying the carb (fairly possible); remove pipe from carb and point into a container while engine is cranked for a few seconds. Or, there's still a blocked jet in the carb. Or, you have a leaking inlet manifold - eg. the gaskets betwixt the carb and mani.
July 12th, 2011, 10:17 pm
