View unanswered posts | View active topics It is currently June 19th, 2026, 12:48 pm
 Front Indicators
Online
Post Front Indicators
For me front indicators seem to suffer from the ingress of salt and water.
An alternative solution...
Purchased this from ebay.
LED panel for 12 volts @ £2.45
Fitted in a Nylon indicator housing, would also work with the metal housings.
Remove the existing wire, contact and spring.
Solder connections, sealed with heat-shrink and glue gun.
Because the array sits further back the lens /diffuser works better and appears as bright as a normal bulb.
Have tried LED bulbs but the cheap items are not very bright.
ps.you will need an LED flasher unit.
June 29th, 2011, 6:00 pm
Post Re: Front Indicators
Looks interesting. What's the difference between a normal flasher unit and a LED one?
June 30th, 2011, 11:13 pm
Online
Normal flasher uses the current from the bulbs to trigger the thermal relay.
LED's only use a few millamps, so no current no flash.
Could use one of these
http://www.ebay.co.uk/itm/Flasher-Can-1 ... _657wt_907
July 1st, 2011, 9:49 am
Online
Converted the Rear Light clusters with these.
http://www.ebay.co.uk/itm/Light-Panel-4 ... 770wt_1398
These will outlast the car and probably me
Front View
Rear View
November 16th, 2011, 4:45 pm
Looks good. Let's see 'em lit up then. 8-)
November 16th, 2011, 6:23 pm
Online
All Light Up.. for xmas
Left Hand - Standard.
Right Hand - Led's.
Side Lights.
Indicator/Hazard.
Stop.
November 17th, 2011, 7:38 pm
Is that not RH - stnd, LH - LED's? Sorry to be anal...
November 17th, 2011, 10:32 pm
Thats clever does the car change colour as well??
looks like top image is red with a white boot lid and bottom two images are white with a green boot lid but same registration!!
November 18th, 2011, 10:38 am
Led's are often less bright, brake light being a good example!
November 18th, 2011, 10:40 am
Online
@Is that not RH - stnd, LH - LED's? Sorry to be anal...
Nope.
All looks different in the flesh.
The "bulbs" show round/halo effect, due to the the lamp and reflector.
@Thats clever does the car change colour as well??
Painted with Thermochromics paint :D
ps The camera never lies.
November 18th, 2011, 11:38 am
Users browsing this forum: No registered users and 207 guests
