Reply to topic  [ 3 posts ]
 Removing door panels
Post Removing door panels
I'm thinking about removing the door panels so I can spray Waxoyl inside the bottom of the door.
Firstly, is this a good idea?
Secondly, how do I remove the panels; and will I need to replace the fixers, whatever they are?
Thanks.
June 26th, 2011, 11:45 am
Post Re: Removing door panels
john end of steel ruler paint scraper etc slipped in under a bottom corner and pull
proper steel spring clips so its not like you'll break the clips
waxoyle of Dinitrol thinned with oil always a good idea but smelly
June 26th, 2011, 12:25 pm
You can lever the door trims off, Try to ver as near to the hidden clip as possible or you'll break them out of the hardboard. You can feel the clips through the vinyl. It won't allow you to see into the bottom of the door though. You need a thin wand to get anti rust wax into them.
June 26th, 2011, 12:28 pm
