View unanswered posts | View active topics It is currently May 2nd, 2026, 2:14 am
Reply to topic  [ 4 posts ]
 sticking steering lock
Post sticking steering lock
Had a nightmare ealier when the steering lock wouldnt come off
put the key in and it wouldnt turn what so ever
i wiggled it pushed it in and out and it just wouldnt happen ;)
in all seriousness though, before you tell me to wiggle the wheel done all that, gently tapped the steering lock, no luck
then suddenly it pinged and went,
i havent managed and dont want to engage the steering lock just incase!
how easy and should i remove the steering lock to prevent this?
Has anyone else had this problem and over come it by doing...?
thanks
June 26th, 2011, 11:29 pm
Post Re: sticking steering lock
take the lock collar off the column
you need a 5mm allen key and you can get to the 2 allen bolts through the slot under the casting
you may have to cut the tin dust cover off first
I never have the lock on the column as the locks are just waiting to fail, no lock and you can hot wire it and drive it.
S
June 26th, 2011, 11:38 pm
viewtopic.php?f=7&t=2737&hilit=sleutel&start=10
June 27th, 2011, 12:13 am
Ahh thanks
it inserts fine but wont turn thats all
its been fine since the steering lock hasnt engaged, just got to make sure it doesnt engage!!
June 27th, 2011, 9:34 am
Users browsing this forum: No registered users and 145 guests
