Reply to topic  [ 6 posts ]
 spark plugs
Post spark plugs
What's the difference between eyquem c42s and c62 plugs?I ask because mine has c62's
and I have some cold starting issues and I believe the c42s are the standard plugs.
Cheers Andy
Life begins at the end of your comfort zone
June 25th, 2011, 1:49 pm
Post Re: spark plugs
According to Eyquem's technical data, C62 is their current plug in the heat range equivalent to the plugs originally fitted.
http://www.scribd.com/doc/40696382/Catalog-Bujii
However, since engines tend to run hotter on unleaded fuel than they did on leaded, a cooler grade of plug than that originally recommended by Citroen is advisable nowadays.
I don't think that you should be fitting C42s, as they are a hotter grade of plug, really only suitable for trundling around town... ;)
Cheers Andy
June 25th, 2011, 4:15 pm
Thanks for that Ken,have to look elsewhere for a remedy for my cold start issues.
Cheers Andy
June 25th, 2011, 4:23 pm
I always found eyquem to go off quickly and were a pig to start. NGK-B7s all the time now
June 25th, 2011, 5:50 pm
Must admit I've always liked Ngk's in general and also denso plugs.
You prefer a b7 Sean do you do a lot of hard/fast driving,would a b6 be more suitable for my mix of town/fast A road Driving (I lost my loony driving hormonesa long time ago.
Andy
June 25th, 2011, 6:09 pm
Yup
dunno try it
June 25th, 2011, 9:40 pm
