View unanswered posts | View active topics It is currently November 19th, 2025, 6:37 pm
Reply to topic  [ 3 posts ]
 Different thrust bearing circlip
Post Different thrust bearing circlip
is there any difference in the circlip/retainer spring between a diaphragm type and coil spring?
I got a new clutch kit (coil spring type), but the circlip/retainer spring is MIA/not in the kit...
Is it possible to use a spring from the diaphragm type on a coil spring thurst bearing?
June 1st, 2011, 9:34 pm
Post Re: Different thrust bearing circlip
Diaphragm one won't work, you'll need this one http://citroparts.com/2CV/Transmission/Clutch/2079/SPRING_THRUST-BEARING_CLUTCH.html
June 2nd, 2011, 8:16 am
Thanks! I managed to gelt hold of the right one!
can continue now with the rebuild of the car :)
June 2nd, 2011, 12:04 pm
