View unanswered posts | View active topics It is currently May 1st, 2026, 9:00 pm
Reply to topic  [ 8 posts ]
 Solid state voltage regulators not up to the task?
Post Solid state voltage regulators not up to the task?
I tested the charge rate on the van yesterday - good job i did!
At idle, it was sitting about 14v and when revved it reached 15.9v before I chickened out.
I tried two of the 'solid state' (three prong) type voltage regulator but neither helped. In the end, we fitted an old 'coiled wire' (twin prong - earth via bulkhead mount) type from a Diane.
The older type have an adjuster inside so you can set the rate of charge. I should have taken photos :roll:
Essentially, you turn a wheel which adjusts the regulator so it outputs more, or less volts.
Hetty is now idling at about 12.5v and when revved goes up to a more sensible 14v.
I'm glad I could cure it this way because (typically) the alternator is a weirdo 60s 2cv one that citroen only fitted specifically to 350s for about 6 months of production :roll:
Some questions:
Why were the two solid state regulators not up to the task?
Am I going to blow up my phone/stereo/lights/battery if the battery is holding 13v instead of 12v?
Can I buy any little plug in thing that will further regulate the power supply so that only 12v is fed to the CD player/12v socket, or does it not matter?
May 25th, 2011, 1:58 pm
Post Re: Solid state voltage regulators not up to the task?
Sam,
I'd guess that the earth lead on the 3 pin plug was not making contact, or isn't actually connected to earth, since electronic voltage regulators are usually directly interchangeable with the electro-mechanical type.
By switching to a Dyane/Ami? type, you've simply bypassed ( another ) problem with your loom, as those regulators are earthed through the bolted connection to the body.
As far as I know, the only difference with those alternators is that they have a couple of 'prongs' poking out of the back, which are connected to the unrectified part of the alternator's wiring.
That's used to operate a 'lack of charge' warning light, via a small box of electronics on the bulkhead.
System voltage in a 12 volt setup is 14.4 volts, so anything which is designed to be connected to a car's circuit should cope with it.
But, if you're worried, fit a good voltmeter.
( No more references to 'Dianes', please, or Hetty will have her name mangled in future posts... :roll: )
Some questions:
May 25th, 2011, 3:22 pm
hmmm, the old one had a wire going to the gearbox, but I guess the connection was iffy.
ken wrote:
IAs far as I know, the only difference with those alternators is that they have a couple of 'prongs' poking out of the back, which are connected to the unrectified part of the alternator's wiring.
Aha! So maybe now the 'zit' on the dash might work?
Cheers Ken :)
May 25th, 2011, 8:02 pm
Sam read my thread on my car
Been there, done that ;)
May 25th, 2011, 9:41 pm
viewtopic.php?f=7&t=2368
May 25th, 2011, 9:50 pm
[quote][Sam read my thread on my car
/quote]
Did you get the T-shirt to James? :D
May 25th, 2011, 10:24 pm
No, but he wants one. :lol:
May 25th, 2011, 10:33 pm
lovin' the snatch
like :P
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
May 26th, 2011, 12:47 am
Users browsing this forum: Bing [Bot] and 114 guests
