| Oil - Everywhere. Smoke too! http://international2cvfriends.com/forum/viewtopic.php?f=7&t=3022 |
Page 1 of 7 |
| Author: | samfieldhouse [ May 17th, 2011, 10:24 pm ] |
| Post subject: | Oil - Everywhere. Smoke too! |
So went for a lovely drive in the van tonight. Had been going about half an hour when the cabin started to fill with smoke. Investigation showed this was caused by oil dripping onto the crossbox and burning off. Smelly, but not a massive problem. It's where the oil's coming from that's the issue. So. There's oil: All over the bulkhead. ![]() In the heat exchanger (right hand side) ![]() And coming out the breather ![]() The situation. This has only developed since we did the tappets, so I was thinking rocker cover gasket, but cant understand why it would be in the heat exchanger if this were the case. The flicking over the bulkhead looks like it could be caused by oil flicking off the brake drums? Not sure. There's also oil at the base of the filler tube: ![]() On most 2cvs the breather is connected to the air box is it not? Now this isn't possible on mine so do I need to connect the breather via a tube to something to stop the oil flying around? I guess I should have listed to that oil drip advisory on the MoT All thoughts and advice appreciated |
| Author: | Sean [ May 17th, 2011, 10:31 pm ] |
| Post subject: | Re: Oil - Everywhere. Smoke too! |
yup open breather would do that run a length of garden hose to an old milk carton or the like fixed to the bulkhead as an oil catch tank A'La Racer the next thing to check is that the oil isnt pissing out an oil feed line to the head tht'd fill up the heat exchanger then get to the bottom of the timing, advanced timing exacerbates the leaks retarded has the exhaust running too hot |
| Author: | Joe [ May 17th, 2011, 10:33 pm ] |
you can divert the breather to a catch tray or to exit below the engine. other than that im no help sorry! |
| Author: | ben [ May 17th, 2011, 10:36 pm ] |
Instant rust preventer. What is that comedy air filter, should the breather be connected back to the carb via the airfilter somehow . Sean, do they use oil like that causing you to have to check it often? |
| Author: | J-dub [ May 17th, 2011, 10:39 pm ] |
i said it was breather too i got something mildly right |
| Author: | samfieldhouse [ May 17th, 2011, 10:40 pm ] |
Cheers |
| Author: | Sean [ May 17th, 2011, 10:41 pm ] |
no not that much - its like blood you need to spill it in alarming quantities for it to be of any danger we had a split hose going to the catch tank a few years ago and it made a real mess got black flagged by yhr marshal in the pits! in the last Snet think we used less than 500ml the equivlent of one of those pop bottles during the 24hrs. |
| Author: | ben [ May 17th, 2011, 10:41 pm ] |
Off subject but am i being thick like just now on my edited post or do those heat exes dump the hot air up instead of out through the wings ? |
| Author: | Sean [ May 17th, 2011, 10:42 pm ] |
samfieldhouse wrote: Cheers yes you can send me the bits or speak to Russ |
| Author: | samfieldhouse [ May 17th, 2011, 10:43 pm ] |
ben wrote: Instant rust preventer. What is that comedy air filter, should the breather be connected back to the carb via the airfilter somehow . There's no air box in existance for an AK350 with an Ami 6 engine Taking a pipe either down to road level or into a box will be the way forward, Box would be more eco and sociable |
| Page 1 of 7 | All times are UTC + 1 hour [ DST ] |
