| Fired up my 8k mile, '1-year old' 2CV. http://international2cvfriends.com/forum/viewtopic.php?f=7&t=2973 |
Page 1 of 1 |
| Author: | Devils Advocate [ May 3rd, 2011, 8:54 pm ] |
| Post subject: | Fired up my 8k mile, '1-year old' 2CV. |
Which had been stored for 20 years. New fuel pump, new fuel hoses, reset points and valve clearances and new oil. Also had to temporarily fit the carb from my running Charlie as I suspect the diaphragms in the original one are shot. Runs booooooootifully Did a cold compression test before starting her up - 150psi on offside, and 160 psi on near (I wonder why the difference?) Once running, I tested the engine vacuum with a manometer - 4" at idle which fell to almost zero on fast idle (I'd guess ~2k) and then it built up to 4" again with revs increased above this. What causes this 'dip' at fast idle? Is it ok? Slight noise from clutch - a 'hissing' sound - at one precise point when it is released slowly; I guess at 'biting' point (even if not in gear)? I guess the bearing will be a little dry? I can live with that (until it goes...). Now to respray the bonnet and front wings - peppered with small rust specks in the paintwork - and the bumpers... |
| Author: | J-dub [ May 3rd, 2011, 10:48 pm ] |
| Post subject: | Re: Fired up my 8k mile, '1-year old' 2CV. |
pictures? why was it stored for so long? my clutch hisses when my foot isnt on the pedal, i suspect release bearing? but anyway it still works |
| Author: | Devils Advocate [ May 4th, 2011, 12:30 am ] |
Hi James. I made a thread on this amazing car when I first bought it last year - it's on the 'Your A-series' forum, and I guess it's time to resurrect it now that I'm finally getting it sorted It's an '89 Special (yep, Portuguese... Apart from the cosmetic specks on the paintwork, the car has no rust whatsoever and is sitting on a perfect, original chassis. Interior not only looks like new, but smells it too... Salivating yet |
| Author: | J-dub [ May 4th, 2011, 12:36 am ] |
almost not worth using it!!! id do a few odd things if it where mine and remove original chassis and store it somewhere (i bet there wont be many truly original ones left soon) and such! |
| Author: | Devils Advocate [ May 4th, 2011, 11:05 am ] |
That's 'odd' indeed! Even by your standards |
