J-dub
 Missing!!!
After borrowing the coil, plugs leads, of my Car, after returning it toy car to use it, it keeps missing as of there was a dodgy connection... No dodgy connection though, Any ideas? I think I need new plugs anyway, What I may do is purchase a new coil ad plugs, use coil for other engine, and new or on this, Inputting I did which may have caused this is not use one side of coil bracket, so ht lead was touching headlamp bar... Could this be the culprit?
| May 1st, 2011, 8:37 pm |
meshking
 Re: Missing!!!
Wait until it gets dark, then start the engine an spray water from a plant mister over the leads, you'll soon see if they are arcing.
| May 1st, 2011, 9:22 pm |
J-dub
 Re: Missing!!!
there only a few months old though...
put tape around headlamp bar where it was touching...
hmmm
| May 1st, 2011, 9:24 pm |
james2cv
 Re: Missing!!!
What do you mean missing? Just when it's ticking over? Mine's done it before; two spark plugs, new coil, some new HT leads sorted it, and the ones that were on weren't that old.
| May 1st, 2011, 10:25 pm |
J-dub
 Re: Missing!!!
just ever now again it misses a beat.. well its got new ht leads about 2 months ago will get a new coil, and i need noew plug these have done about 8k!!!!!!
| May 1st, 2011, 11:32 pm |
J-dub
 Re: Missing!!!
i think it could be the plugs as i also borrowed these. i took the plugs out and cleaned them after it kept missing, and it is a bit better now, doesnt miss as often, so im thinking its down to plugs as especially as ive done a lot of miles on this set and they look fairly worn.. typical it being a bank holiday, no where is open to get me some plugs, so will have to wait until tuesday or whenver going to dispatch my mate to get me a box of ngk's so then hopefully ill get the problem sorted that way, if not, new coil it looks like.!
im going to try another set of ht leads tomorow on my way to work so i can rule that out
| May 1st, 2011, 11:54 pm |
Joe
 Re: Missing!!!
have you checked the plug gap?
| May 2nd, 2011, 12:59 am |
Chris 2cv
Joined: February 2nd, 2009, 10:25 pm Posts: 293 Location: Hampshire
 Re: Missing!!!
Did you leave the circuit with the coil connected into it connected for a long time? did you notice the coil getting warm?
| May 2nd, 2011, 1:26 am |
 Re: Missing!!!
Jameswallace wrote: Inputting I did which may have caused this is not use one side of coil bracket, so ht lead was touching headlamp bar... Could this be the culprit? James chop about 1cm out of the top of one of the hoops and its easy to get the coil in and out
| May 2nd, 2011, 9:19 am |
J-dub
 Re: Missing!!!
thanks sean
and no didnt leave coil on for more than i ever had the engine cranking so wont of got a chance to cook plug gap is fine but will check later
0.6mm?
| May 2nd, 2011, 7:45 pm |
Users browsing this forum: No registered users and 97 guests |
