 Breather Overhall
Post Breather Overhall
Having seen Russel's recent good work, It spurned me on to fix my breather.
I have made "clamp" to allow the breather parts to be re-connected.
Research on-going for valve material, use rubber in the short term as you will be able to dis-assemble your breather.
If there is any demand I can supply these ...
Bottom has gap to fit over dip stick connection
Top part in two halves
12 off 4mm bolts and nylocs.
Cost including p&p about £20.00
April 14th, 2011, 5:04 pm
Post Re: Breather Overhall
Some "How to..." Pics
Bench Grinder allows some control when grinding
Grind round the seam, just enough to be able to prise it apart
Clamp Fitted
April 14th, 2011, 6:56 pm
id have one of these for future occasions ;)
April 15th, 2011, 1:52 am
Re-furbished the internals of the breather, will now out-last me and also the car.
Tested with my new manometer and get 4.5cmm of vacuum at a fast tick-over and 0cm at high-revs
April 19th, 2011, 5:38 pm
That's excellent stuff, Pete. What material did you end up using for the rubber diaphragms?
April 19th, 2011, 9:21 pm
Shim steel, very, very fiddly to cut and make flat...but its works.
Improved vacuum with better starting and an "stable" tick-over.
Will also check the mpg as i believe that also will be improved.
May be make-up some "replacement part" if there is an interest.
April 20th, 2011, 10:01 am
Oooooh, shim steel? That sounds goooooood. Working a bit like the 'reed' valves on 2-strokes engines?
April 20th, 2011, 6:20 pm
better running etc as to a normal brand new replacement?
April 20th, 2011, 11:39 pm
@DA
Copied the idea from ECAS CPD valve.
@JW
Vacuum of 4.5cm is good I think......feedback here please.
I dont have a new breather to compare, if you have one to lend I'd be happy to do some tests.
April 21st, 2011, 10:10 am
Did you measure it before you did anything to it? I hate to say this, but I'm afraid it's not working optimal, as the vacuum should never fall to zero if stuff is working.
This is what the Citroën manual says:
The difference in levels should be:
- With engine idling: Minimum 5cm. The vacuum should never fall to zero, no matter the engine speed. Otherwise the breather must be replaced.
To compare, I think my new one had 7-8cm difference.(maybe I remember wrong)
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
April 21st, 2011, 10:32 am
