Joe
 Roof straps.
Is there anything i can do to make them work better, or failing that, something to use as a back up? they keep coming undone when the roof is fully back if i hit 50 mph, i don't mind but the rear view mirror is somewhat obscured and i use that quite a lot.
| April 7th, 2011, 2:12 pm |
terpineol
 Re: Roof straps.
Pick your favourite hammer, and put it down in favour of a smaller one.
Then gently apply a beating to the male side of the poppers to widen them out a bit.
Works for me.
| April 7th, 2011, 2:46 pm |
Joe
 Re: Roof straps.
I know the poppers must be suitable for the use, as nothing on this car seems to be over or under engineered, but for peace of mind is there something more substantial that can be done?
| April 7th, 2011, 3:19 pm |
Erasmo
 Re: Roof straps.
I would go for replacing them, new ones that fit tightly should hold even at top speed.
| April 7th, 2011, 4:02 pm |
Squeezebox
Joined: February 8th, 2009, 11:39 pm Posts: 813 Location: East Sussex
 Re: Roof straps.
Joe wrote: Is there anything i can do to make them work better, or failing that, something to use as a back up? they keep coming undone when the roof is fully back if i hit 50 mph, i don't mind but the rear view mirror is somewhat obscured and i use that quite a lot. But he was going above top speed
| April 7th, 2011, 6:53 pm |
james2cv
Joined: April 18th, 2009, 8:01 pm Posts: 947 Location: Paris/Manc
 Re: Roof straps.
I find if you roll it back with the inside on the outside, and pack it tightly, it's a lot less prone to this happening. Not the ideal answer though. Sorry
| April 7th, 2011, 7:09 pm |
Joe
 Re: Roof straps.
Squeezebox wrote: Joe wrote: Is there anything i can do to make them work better, or failing that, something to use as a back up? they keep coming undone when the roof is fully back if i hit 50 mph, i don't mind but the rear view mirror is somewhat obscured and i use that quite a lot. But he was going above top speed  haha, ill have you know that i have had this car off the speedo with the wind behind me down a hill. I think it works out at a scary rpm though!
| April 7th, 2011, 7:33 pm |
Jonathan
 Re: Roof straps.
Best to buy new straps, but in the mean time you can use a small flat screwdriver to 'close' the eyelets on the strap so they fit a bit tighter. Don't over do it though.
| April 7th, 2011, 10:44 pm |
Ventflaps
Joined: December 29th, 2008, 12:16 am Posts: 193 Location: South London
 Re: Roof straps.
There's two very effective options which I know directly of.
My solution was to fit some one way press button studs: they look like the original fittings, but the button can only be lifted off by pulling upwards from one side only. When correctly fitted, the constant pull in use is from the long end of the strap and it resists it completely, but a quick pull on the short tab unfastens it. Unfortunately I found that they wore out quickly and so I reverted to standard, but I did 360-ish miles yesterday with the roof rolled back at speeds of up to (briefly) 75mph. But I do frequently check them in my rear mirror and a few years ago did find that one had come unfastened. The standard fittings usually work, most of the time, but as they have no failsafe they can never be fully trusted.
Ryo Hayashida's solution to the same issue was to fit Tenax fasteners. The female stud on the outer roof is replaced with a short male pin, and the straps have the male studs replaced with female receptacles. The permanently anchored end of the strap is just secured by directly screwing it to the metal with washers to spread the load and allow rotation. It doesn't look original, but on balance is a much better solution and doesn't look unsightly.
I have seen the results of a rolled roof suddenly letting go at speed and it's definitely something to be aware of, both for cost and safety grounds.
_________________ The difference between the almost right word and the right word is really a large matter.
| April 8th, 2011, 12:04 pm |
Joe
 Re: Roof straps.
Ventflaps, thanks for the concise reply! I do recall seeing Ryo's thread a long time ago. i might pop down to hobby craft and see what i can find. it sounds like a good compromise with theses studs rather than what i was thinking of doing involving a load of bungee chords. etc.
| April 8th, 2011, 12:11 pm |
Users browsing this forum: No registered users and 98 guests |
